How hard can you cut back a hedge?
22 Nov 2018
This hedge hanging massively over pavement. Can I cut it back to edge or will it remain brown forever if I do? Looked for green beds in what was left after I cut it back. Found one
I'm not an expert and don't know what type of shrub or hedge that is ( possibly privet )but my guess is that the side in the pic. is north facing or gets very little sunshine. If it were mine I would cut it back very hard,to about 4 foot high and definately off the pavement. Then thin the other side until it was a about 2' 6" deep. That should allow more sun to get through to the pavement side and thicken the hedge evenly when it regrows. I would guess it's pretty fast growing so once it gets to the dimensions you require trim both sides regularly and don't let it get out of control again.
According to Google's image search:-
"The plant in the image appears to be an Elaeagnus hedge, such as an Ebbing's silverberry (Elaeagnus × ebbingei) or a similar oleaster variety".
And according to ChatGPT:-
"Oleaster (Elaeagnus × ebbingei) generally responds very well to hard pruning and can regrow vigorously afterwards.
It tolerates being cut back quite severely, even into older wood
The best time for a hard renovation prune is late winter or early spring, before strong new growth begins.
If the hedge is very overgrown, you can reduce it substantially, but for a very severe cut it can be safer to do it over 2–3 years, rather than removing everything at once."
not 100% sure, but you could probably cut that back to a 6" stump poking out of the ground - it would probably go back 5 or 6 years - don't let it get out of control as much the ext time
It certainly should be cleared off the pavement, otherwise the council could do it and bill you a fair whack for doing so.
BTW, the photos show it AFTER I've cut it back, shall I carry cutting it to the edge of path?
If I was doing it, I'd cut it back further, lower the height, and at least attempt to cut it in a straight line...
As above, hit it hard in winter.
There's a lot there, so maybe do it in a few sessions. Clear away as much ivy as you can, there's lots of it creeping along the pavement.
