How Is Any "Normal" Person Supposed to Make Sense.
24 Sep 2010
Oxfordshire
......of the buildings regulations :?
Its quite a number of pages long, filled with all sorts of jargon. Just looking at the table of contents makes me want to bury my head in the ground and let the worms eat my eyes out.
I want to do i little loft conversion (no building, no extending, just moving a stud wall, insulating, boarding etc) which i am more than capable of doing myself but how do i know it conforms to the regs without having the read it?
I'm new to all this. There must be an easier resource.
Well this document is pretty handy http://www.trussloft.co.uk/Downloads/Loft-Conversions-and-the-Building-Regulations.pdf although its a bit out of date in terms of fire and insulation regs. Importantly though (as that guidance is a bit out of date) for a guide to the fire regs look here http://www.google.co.uk/url?sa=t&so...tjhwgZHdA&sig2=YMfxxJP9CILQt3bXmSTNGw&cad=rja
This is a more indepth guide: http://www.constructionproducts.org...roducts Association Loft Guide March 2010.pdf
Frankly though why don't you employ someone to do you some drawings chances are you're gonna need a structural engineer too.
There's not much you can't find an answer to on this forum though.
Chestercopperpot, we all know that builders and other tradesmen are not really "normal" :D
LOL ... I'm nominating that for the DIYnot contradictory statement of the year award
Do you really think that you are capable if you don't know what to do?
Hi Chestercopperpot,
This brief answer for you is this.
As you're not changing the external look of the roof, or the structure (load-bearing) in any way, you'll be able to move non-loadbearing walls without permission under PD (Permitted Development).
What you're describing is probably one up from decorating, so you will be fine. However, do take care that you do not affect the structural integrity of your home.
I hope that helps.
Many thanks,
Chris
LOL ... two nonsense comments in the same thread. This ones a winner
So for this loft conversion should the OP get a painter around to design the steel beams, advise on means of escape, and design the insulation and ventilation?
One up from decorating indeed :lol:
He is 'only' moving a partition, he has not mentioned if he will make the space a habitable area.
If he said he was going to make it a bedroom, it would have been a completely different response, and as you've commented, a full design would be required incorporating all applicable building regulations requirements. But Chester is doing a simple job, it required a simple answer. Provided he's not loading the existing joists to excess, it's not an issue, *most* floor joists are designed to accommodate a typical Universally Distributed Load, that expected from a loft storage area.
I had hoped I found a forum where members helped each other, but perhaps not? I love sarcasm and degrading others as much as the next adult, but surely constructive comments would help a little, every now and again?
What the f**k do you know about that, with 6 posts to your name? Muppet! :roll:
Psst, posts on one forum in the world, isn't the sum of all knowledge. :wink:
I had a theory, I would join this website so that I could help others - I don't think there's anything wrong with that, is there? The hope was that one day I could ask a question and be helped. Is that wrong?
I see a lot of people on here who post a question and then bug*er off, never to be seen again. I'm doing the opposite and yet I'm getting grief, is that how this forum is supposed to work - I thought it was collecting knowledge and helping each other?
All the best.
I had a theory, I would join this website so that I could help others ... [etc]
Chris, you need to toughen up a bit. We've already got a couple of sensitive planning guys on here, so the quota is full.
Be prepared for some ribbing, and personally I reserve the right to hit people around the head with their own comments
Now, if you read the OP, you will see that he is planning a loft conversion. The OP's own lack of knowledge has meant that he has discribed this as "just moving a stud wall" etc but that clearly is not all that will be going on
So I'll give you a second chance, and you should also give our own Victor Meldrew (aka FMT) a second chance too :P
