Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
When did the rules change such that you can now pump the mains?
What is normal natural gravity flow rate when coming off a 22mm mains say for London or Herts?
London is frequently awful. 2nd and higher floor flats often need an accumulator or break tank & pump. Either of which can be less hassle than replumbing in larger pipe which can make little difference.
