When did the rules change such that you can now pump the mains?
What is normal natural gravity flow rate when coming off a 22mm mains say for London or Herts?
London is frequently awful. 2nd and higher floor flats often need an accumulator or break tank & pump. Either of which can be less hassle than replumbing in larger pipe which can make little difference.
