To assuage the OP's worries, here is a 4.5m opening, 4 strongboys, a few props under the floor; no method statements, clipboards, CDM or hi-vis around. Job done, no problems. Most of this is down to experience.
Because like me, he's an ugly $od! (only joking!)To assuage the OP's worries, here is a 4.5m opening, 4 strongboys, a few props under the floor; no method statements, clipboards, CDM or hi-vis around. Job done, no problems. Most of this is down to experience.
never mind all that, why is he allowed on site with no face![]()
The spacing of a prop or strongboy depends on the type of wall construction among other things. I've done jobs like this on different types of walls such as Bungaroosh, Random stone, 9 inch solid, cavity cement or lime mortar and a judgement has to be made on site. Many of the houses round here are 20 inch stone so require a bit more care when propping.
Apologies for butting in - we're planning a 4.1m opening in a stone built terrace c1901 (wall about 40cm thick).
Presumably this would require a lot more planning, support than an equivalent brick span?
Is there anything I should be looking out for / discussing with my builder about this?
No; the props remained until a new 1 brick x 1 brick pier was built.Because like me, he's an ugly $od!
More likely a cash job.(and ugly)
Is that all sitting on 130mm of pier? I like it.
If someone has a builder whose work they have to question on an internet forum it may be worth changing your builder.
Or the builder changing their customer?
I wonder how many general builders understand their responsibilities and the outcome if failing to comply becomes apparent
They weren't talking about you, they were talking about him:And yes, maybe not that great looking.!
