how much for the following
23 Apr 2011
Derbyshire
replacement double glazing unit (supply and fit) just the unit
size 210 x 80 x 40 for our lean to conservatory
i look at a few prices online and it seems around the 70.00mark
are taking the beading off problomatic on a old window???
thanks
If its a standard timber frame using glass beads, then no real problem other than care and patience.
You'll need a broad blade chisel, hammer and a pair of pincers to pull out the sprig nails.
If the beads do snap, Wickes etc have ready moulded sections in soft or hardwood.
John :)
Ok, no problem - so long as the glazing beads don't break!
Professional window fitters have remarkable skill in removing these without marks or damage and they could see to your window in 1/2 hour.
Usually its sticky both sides tape thats used to keep the pane in place.
Although the glass beads are more forgiving in warmer weather, they still tend to get brittle, presumaby due to uv light action.
John :)
how much do you think i should be charged for fitting if the window comes up at around 70.00 looking on line? thanks
Thats impossible for me to say - its only 1/2 hours work so long as nothing goes wrong.
Why not use a local guy? He'll measure, order and fit the unit for you, and I'm sure his charges will be reasonable. Thats what I do every time, and I've always been more than happy with the price. I don't think he'd take too kindly to me supplying the DG unit though!
John :)
have contacted a few companies all quote around 70.00 for the panel just waiting for hear back from 3 companies for them to price for the work to be carried out
so if they measure it wrong its there fault
if they stuff up the beading its there problem
lets hope they dont charge much :)
least i know how much the glass is :)
