Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
I’d not use fishing line, I’d worry it would slip under the staples. Basically, anything that won’t rot and that you can staple or otherwise fix in place. I confess, when I wrote “baler twine” I actually meant “bale strapping” but either would be fine.
funnily enough this is exactly what I am working on as well. I highly recommend to do a proper job even though it is pain to crawl. Previous owner of my place (or their builder) thought it would be best to just dump a lot of building material into the void to hold up the fibreglass wool.. I am currently clearing everything out and using light netting to hold everything back up. Empty spots I use some leftover rockwool slabs which stay in place w/out (but I will still add netting).
I am using this and it works perfectly fine. Having a cordless staple gun makes this much easier (I purchased on solely for this).
