Hi everyone
This is my first post in here as I'm properly stumped on what to do next. Any help would be appreciated.
I have 15m2 of utility area to do up. Currently it's no more than a concrete slab coated in what I think is some kind of (blue) epoxy. Half of it is smooth, the other half is about 3mm lower and rough. I have some DPM sheet but want to level off the surface first. Should I use something like latex Arditex NA? Will there be an issue adding DPM sheet above? Should I use a liquid DPM on top instead?
Aim is to get this prepped for 18mm T&H chipboard then laminate. Only have a total of 38mm height to play with due to existing door thresholds, hence not adding any insulation etc.
GMAD
GMAD
