Just got a new basin tap. The holes for the flexis are way deep inside. I presume they don't need to be mega tight with the o rings on the shaft but surely finger tight is a bit slack
Finger tight is fine on these. (Gorrilla hands not necessary!) double o ring makes them pretty foolproof. It will probably say in the manual finger tight only, so just screw them in until they stop. Job done
