hi guys,after my last attempt at fixing my CH motorised valve,i got the system drained,valve replaced,but the header tank was full of soft sludge,the system was refilled without adding the inhibator.
what im going to do is tie up the ballcock,plug the hole into the system and clean out and wash the header tank.
now my question is,if i unplug the hole from the header into the system,add the inhabator[is there a special one i need] into the header tank and release the ballcock and let the header tank fill up,will the inhabator go around the system or do i have to completly drain the system again.
many thanks.
LP.
PS the water that came out when flushed was clean as a whistle
many thanks.
LP.
