How to add socket
20 Oct 2010
Lanarkshire
Hi I would like to add another double socket to this back to back in a cupboard to power a router. There is no play in the cables to extend the ring so either I add another set of cables to this and try 3 into each terminal and run a radial or what would you do ?
You can just run one 2.5mm cable from the existing socket can’t you?
