Can’t be totally flat with grout lines.Already attempted it. Stuck one plank down well for a few hours. Later in the day, the plank popped off the porcelain tiled surface. Without a doubt, I need some kind of adhesive that bonds well for two non porous surfaces.
The surface is clean and totally flat. It'd be a real shame if I had to overboard with ply and stick the peel & stick onto the ply. I don't want to raise the floor height if I can help it.
You also said, "Can’t be totally flat with grout lines." The tiles pass the credit card lippage test.Always struggle if you cut corners.
One less dumb post to answer .You also said, "Can’t be totally flat with grout lines." The tiles pass the credit card lippage test.
I've looked at some of your post history. You have form with your meaningless and unhelpful one-liners in response to members who simply come on here to ask for help. You sir are a provocateur. I have blocked you.
@foxhole But you didn't answer the post. Says all we need to know about you and your trolling. It appears that you don't know the answer to my question. No shame in that F Hole!One less dumb post to answer .
@foxhole But you didn't answer the post. Says all we need to know about you and your trolling. It appears that you don't know the answer to my question. No shame in that F Hole!![]()
Thought you blocked me .@foxhole But you didn't answer the post. Says all we need to know about you and your trolling. It appears that you don't know the answer to my question. No shame in that F Hole!![]()
