We want to knock down the small existing shed in the garden and replace it with a garden room. Am I best:
a. Buying an off the shelf timber "garden room", probably 33mm or 44mm T&G - which sometimes pop up second hand on eBay. I would then insulate and plasterboard it.
b. Build one from scratch?
If building one from scratch is the solution would I be best making a frame from 4x2, covering with breathable membrane, batons and cladding, then internally fill the frame with cellotex, cover with non-breathable membrane and then plasterboard?
c. Use SIPs - if so, how easy are these to use?
Sorry if this is very basic - just trying to work out the best approach early on.
