How to close my cavity...
11 Feb 2013
Essex
Hi guys, im building a conservatory 3mx5m and i need advice to close the cavity, on the 3m flanks there are no windows and the brick and block goes all the way to the pitch plastic roof, so if you look out one of the second floor windows you will see all the cuts and open cavity, i also dont want moisture driping down of the roof into the open cavity. Any advice or tips would be welcome. :?
If i understand you: there are various custom cavity closers available, and various other methods of closing cavities. google them up.
Perhaps post some pics of your project.
I will post pics up as soon as im out of the ground :D , what im trying to say is that my brick and block work will be coming down at a slight angle and im looking far a cavity bar that will cover the cuts on the brick and block as well as close up the cavity, so 100mm block 75mm cavity and 100mm brick.
