I want to start putting up some lining paper but wanted to check what is the correct method, I intend to:
1. Draw a straight line using a level a bit away from the the first internal corner
2. Put up first paper along the line
3 When I come to the corner I will just cut into the corner as tight as possibe
4 Then continue the some method for the next wall
Does this sound correct? and is there anything I am missing or need to be aware of?
Thanks.
Thanks.
