How to fit howdens leg pack
21 Jul 2004
Hi, have been given a leg pack for a unit. See pic. Not sure why they didnt give normal legs which only requires a single hole to be drilled into underside of cabinet.
Im using a wall cabinet on legs to conceal a gas meter.
Anyone know what type of drill bit to make the holes for this fitting?
Tia.
As it won't carry any weight, cut off those 3 bits sticking out and use the other 3 holes to secure the legs to the cabinet with screws.
Otherwise you will need to measure those bits, mark them on the cabinet and drill holes of correct depth and diameter.
Cut them off!
Just go out and buy the right sort of legs. Makes life so much easier than trying to bodge something together. I know its a diy forum but sometimes spending a fiver is worthwhile.
