Whats the best method for fixing a, say, 2x3 frame to a brick wall?
First of all, I assume I'd want the verticals to be at 600mm centers in order to make fitting the plasterboard easier.
1. What size of screws should be used?
2. How far into the brick to drill?
3. Best type of rawlplug/fixing?
4. How many fixings per vertical?.
5. How do you line-up holes drilled into the wood with holes drilled into the brick?
I read somewhere you could drill thru timber with a masonary bit into the brick, then push a plug through. But surely the hole in the wood would then be too big?
Its a 2.8m ceiling. 12mm plasterboard will be fixed to the frame. Of the four walls:
1. One is a brick wall between two Victorian flats (lots of chimney flues behind wall). I plan to add 50mm rigid foam insulation behind the plasterboard.
2. Another brick wall is internal, and I want the frame in order to support shelving.
3. Third wall is a lathe and plaster partition between rooms, so I'll already have the timber frame there
4. Fourth wall is an external wall with partial coom ceiling and dormer window. I plan to put 100mm insulation behind that, and perhaps plasterboard with 25mm insulation.
Ian
Ian
