How to fix (to a wall) a mantle
17 May 2011
Cambridgeshire
Hello Again,
I am in the process of changing from an open fire to a wood burning stove. I am planning on having an oak mantle. The question I have is how should I fix it to the wall without seeing the fixings?
In the pictures (yellow box is where I plan to put the mantle) you can see that there is a concrete support that sticks out 20mm, I plan to router out the back of the wood so the oak will still sit flat to the walk. However the concrete support is angled (in the fireplace) so I cannot drill into the support, So I am not left with allot of space.
All help (apart from “no more nails” is welcome.
Thanks in advance
Steve
Hello Again,
Thanks in advance
Steve
Hi Steve
Cant see the photos? :?
Brian
You can use a 'L" shape metal bracket, and either chop a bit of plaster out and then fix and fill over, or fix the bracket to the wall first and fix the timber over it
You could fit large L brackets to back of mantle at base and screw to underside of the chimney opening. Would not bother with router just chip off excess brick so it's flush.
A completely secret method of fixing is to use allthread and resin. To do this drill holes into the wall and corresponding holes into the back edge of the mantle. Drill the holes slightly larger than the allthread dowels to allow for positioning. It's easier to fix the dowels into the timber first although the whole job can be done in one go.
Dry fit the whole thing first and cut some timber props to hold it all in place , then inject resin into the holes and push together and hold it up with the props. Resin will set quickly but give it an hour or so and it will be secure.
Downside to this method is that it isn't very easy to remove and whoever does will probably resort to destroying it to get it off the wall.
Plenty of resins around for this job. L brackets are too ugly...
