- Joined
- 13 Jul 2007
- Messages
- 118
- Reaction score
- 0
- Country
Hi, I'm in the middle of re-doing my en-suite from the ground up.
My problem is the walls in the shower area. They are not straight at all and I'm going to be fitting 40cm x 30cm tiles which at the moment will look a mess unless the wall is flattened.
If I lay a long steel ruler accross the walls (they are fine in the verticle) there is upto 7mm varience in the surface in two nice uniform waves.
The walls need re-skimming anyway as I need to make good around the tray and where the old power shower was mounted.
I will be plastering them myself but I've never done it beofre although I am reasonably competent at most DIY taks.
What is the best method of skimming the walls to get them flat, and what tollerence should I be aiming for to leave a flat enough surface for my tiles?
Thanks in advance!
Thanks in advance!
