Any advice much appreciated. I have removed a gas fire and had a gas safe engineer cap off the gas pipe away from the fireplace. I want to make he opening usable for a solid fuel open fire. I have had a HETAS engineer around and he said everything is good except that i need to put in a throat forming lintel around 60cm up from the existing floor.
Currently the opening is 94 cm high from floor to flu and existing lintel, and around 47cm wide.
The lintel i have bought is the smallest i could find and is 86cm wide (same as existing load bearing lintel). So i need to knock out some bricks 30 cm or so below the existing lintel and put this in.
My question is: how do i support the existing lintel while i am removing bricks? At first I though of hiring a prop and putting it in the centre of the existing opening, but then it occured to me that in doing so I wont be able to get the new lintel in as the prop will be in the way. Am I missing something, is there an easy way of doing this? Or maybe i shouldn't worry about support? Any ideas?
Thanks.
Thanks.
