How to lay electric under tile heating
12 Jun 2009
I'm putting underfloor heating in and tiling the bathroom floor on top. First floor and over floorboards. Is the following a good way to do this?
Lay 6mm hardiebacker across floor with mortar underneath to even out floorboards
Layer of flexible tile adhesive (3mm?)
Then underloor heating layer
Then tile on top using a layer of flexible tile adhesive
Any advice/corrections please
What do the instructions say? Or are they the instructions? If they're the instructions then fold them carefully and place them in the bin.
I'm putting underfloor heating in and tiling the bathroom floor on top. First floor and over floorboards. Is the following a good way to do this? Lay 6mm hardiebacker across floor with mortar underneath to even out floorboards
AS already said, start with the manufacturers instructios; nothing wrong with Hardibacker but what thickness? If you’re going for an electric UFH mat (questionable & expensive if it’s a secondary heat source), I’d start with a suitable insulated backer board & lay the mat over that.
Lay the heater mat & then an SLC over it if you want any chance of repairing it in the future & to protect the cables from ham fisted tilers :LOL: ; it will also provide a flat tile base which is important if your laying large format tiles.
That’s about right but it should be the correct (powder cement) adhesive for your tiles & use the correct trowel for you size tiles; you also need to use quality trade tiling products, the cheap own brand & DIT stuff is mostly crap.
screw exsisting down every 200mm
then as rich has said...
only thing when covering the elect ufh use a latex based slc and when pouring and working it,use a plastic trowel so you wont damage it..
dont run the ufh under any white goods..
make sure the addy is ok for elect ufh as well.
And please don't forget to position the temp sensor sensibly so that it can be replaced if it fails. Best to run it in some plastic trunking or conduit slightly cut into the flooring, and then with the end exposed somewhere (cupboard/stud wall) so that it can be drawn back.
As an electrician I have seen a number of installs where the client has had to completely re-tile in order to replace the sensor...
