How to lay Luxury Vinyl Click Flooring and sub floor?
27 Jun 2017
Hello
ive had a look at a few videos but ive never actually fitted any of this stuff.
Ive dont plenty of laminate and oak etc and im guessing it goes in quite easy.
here is the stuff
http://www.diy.com/departments/colo...vinyl-click-flooring-149-m-pack/539744_BQ.prd
1st is sub floor.
its going in a bathroom over timber floorboards.
id assume 6mm ply overboarded ontop of the floorboards is enough? ive also seen some just suggest hardboard? is 6mm overkill ?
underlay:
whats best to use for this over the ply/hardboard?
the white foam 1mm stuff, the green foam 3mm stuff, or the silver backed 3mm?
links here...
http://www.screwfix.com/p/acoustic-polyolefin-foam-underlay-20m/4720r
http://www.screwfix.com/p/acoustalay-foam-underlay-10m-x-1m-x-3mm/7362g
http://www.screwfix.com/p/duralay-p...0m/48485#product_additional_details_container
Fitting:
After the 1st row is done, on the 2nd row onwards, it seems like you somehow 'click' either the small length or longer length into position and dont have to tap it in? i assume its easy to do but there seems to be different methods?
Expansion gap:
ive seen from 2mm to 5mm listed.
anything else to add?
thanks in advance
okay thanks
yes i was thinking of just going with the ply however B&Q said to use an underlay.
hi
in bathroom with wall tiles and flooring as above,
would you tile all the walls apart from the bottom row, then lay the vinyl click floor then put in the bottom row of tiles so its ontop of the floor.
or, tile to the floor, then fit the vinyl, leave a 2mm gap and then it would have to be siliconed around the edges really.
If tiles off I'd do last row ontop of the floor. No silicone then. But a thin bead in clear looks good anyway
