How to make thick sides to shelving unit
  • Thread starter Thread starter imamartian
  • Start date Start date
I
imamartian
Hi all. If i were considering making a unit similar to the one in this pic:
http://www.propspropsprops.co.uk/images/gallery/l/62029_57533.jpg
Can anyone advise, firstly, how i might make the thicker side panels - i'm assuming they're not solid. And secondly (and probably a question for a different forum) can people suggest ways to give them a decent finish? For example, i have used mdf kitchen cabinet paint in the past, and was really impressed..
Easiest way is to make a sandwich from two sheets of 13mm veneered MDF with an MDF core to give the required thickness. If you keep the overall to less than 50mm you can buy matching iron on veneer to cover the edges.
Jason
laminate them,
i:e either glue or screw them together,but you can get 1inch thick mdf would that not suffice?or does it need to be thicker?.
if you plan on anything of any weight for on the shelves i would forget the wheels as it will weigh a ton and on that span will sag :wink:
jasons torsion box design will support a lot more weight but still do without the wheels as it will be to heavy to move if well loaded
ta for the replies...
no wheels, as it's going to sit on another unit.
As for the iron on lamintate thing... i've never been a fan....
What about two 25mm boards, laminated, but with 45deg mitres edges, and a trangular strip of the same timber glued in to give a clean edge?
Like this....
_________
________/ /|
________\ \|
Probably as easy to just use flat timber lipping about 6mm thick. Don't know what machines you have so can't say how accurate you will be able to cut the mitres, could try a mitre-lock cutter in a spindle moulder if you have one.
Jason
Jason
Thanks, that sounds like a better option.
I have a decent sized table saw, and a fairly decent mid-range router...
but the flat timber lipping gives me better corners....
