    Dismiss Notice
how to mix pointing dark coloured
Discussion in 'Building' started by bmx, 2 Apr 2012.
  1. bmx
    bmx
    3 Sep 2005
    66
    Thanks Received:
    Country:
    after some advice on mixing some pointing. i want to repoint the front of my house in the next week or so and i want a dark grey colour similar to marley modern tiles. whats the mix needed for this or a very dark grey mix please :)
  2. Sponsored Links
  3. PrenticeBoyofDerry
    PrenticeBoyofDerry
    30 Jun 2009
    21,628
    Thanks Received:
    2,383
    Londonderry
    Country:
    Trial and error, using dark sands and grey cement maybe even the addition of black pigments will help. But you will need to sample test a few mixes and leave to dry to see what the outcome is.
  4. stuart45
    stuart45
    13 Sep 2008
    3,092
    Thanks Received:
    472
    Somerset
    Country:
    You need to leave the samples for a few weeks as the colour will lighten in time.
  5. bmx
    bmx
    3 Sep 2005
    66
    Thanks Received:
    Country:
    Ok any starting points? I was thinking 1 building 1 kiln dried 1 cement . What do you think? :)
  6. themiddleagedun
    themiddleagedun
    8 Jun 2010
    323
    Thanks Received:
    68
    Lancashire
    Country:
    Just use cement & building sand. 1 part cement-5 parts sand plus the addition of a black mortar dye :)
  7. hammerswinger
    hammerswinger
    26 Jan 2010
    315
    Thanks Received:
    26
    Tyne and Wear
    Country:
    It's worth bearing in mind that the cement used can make a big difference to the finished colour of the mortar, if you want it dark you're best to use just ordinary Portland cement and stay away from the multi blended cements like mastercrete as these tend to give a much lighter finish.
  8. peekay53
    peekay53
    22 May 2011
    668
    Thanks Received:
    95
    Merseyside
    Country:
    also unless you are using proper guaging techniques mix it all in one go and complete the job or you will find sat / 2 /3 shades different
  9. DIYnot Local
    3 Sep 2019
    Country:
  10. Sponsored Links
Loading...
Share This Page
