- Joined
- 17 May 2012
- Messages
- 11,444
- Reaction score
- 1,039
- Country
OK, so I am soon to internally insulate and plasterboard another room, but this time I want to put a radiator on the wall. Will be using Evergrip pink foam to stick 50mm Kingspan to brick wall, then stick plasterboard to that.
What is the best way to do secure the radiator? Should I just screw on the wall a couple of blocks of wood instead of insulation where the radiator will hang? If so, how much? One long piece at the correct height, or a couple of 100m squares at exactly the right spot? Or is there a better method? Will obviously have cold spots, but will be better than big holes when if falls off .... Will cover in insulation tape to restrict moisture transfer as much as possible.
The wall:
The wall:
