Can I put slight pressure on a plastic compression t to enable my 1 1/2 inch Kitchen waste to slope over 1.5 m ? Or can I bend the plastic drain 1 1/2 inch pipe ?
I need 2 waste pipes approx 1.5 m long each, to exit into drain from opposite directions so require to use a plastic compression T. each pipe is about 1.5 m long. As the t will have to be horizontal, how can I get the pipes to run on a slope ?
thanks
thanks
