- Joined
- 16 Aug 2021
- Messages
- 6
- Reaction score
- 0
- Country
Here is a picture of the kitchen waste on my new house:
The white pipe with the dog leg is my kitchen waste. The straight white pipe is my neighbors kitchen waste and the small bottom pipe I think is lead and probably my old kitchen waste not in use.
They are join into the grey soil pipe running horizontally across the front of my house which has a rubber coupler on the end connecting to a clay 90deg bend through the wall.
The other side of the wall is this:
The wastes exit into this gulley with a little cracked conrete channel to feed the water from the clay pipe elbow into the drain.
I am looking to replace soil pipe with normal 40mm waste pipe and change the grating cover on the gully to one with a waste pipe inlet to neated this all up.
I have a couple of questions. I don't want to cause hassle with my neighbour about their kitchen waste draining into my waste pipes even though I'm sure it shouldn't. Is it a problem to have the waste from 2 kitchens going into the same waste pipe and could it cause issues if say 2 washing machines are emptying at the same time? Also do you think there is enough drop on the waste if it starts where it exits my neighbours kitchen (the middle pipe). I was thinking to drop my waste pipe vertically down into a T to meet this pipe.
