The drain/fall pipe from the conservatory runs at an angle/diagonally under the kitchen window to the drain.
Just fit a new kitchen and I need to plumb in the sink. This waste pipe needs to exit the wall and go to the same drain as the fall pipe from the conservatory.
Is there any reason why I can't run the 40mm waste pipe from the kitchen into the fall pipe using a boss? as opposed to taking a full run of 40mm pipe to the same drain.
