How to remove Bosch bit?
19 Feb 2015
I've just got one of these bit sets pictured. I placed one of the bits into the holder and used it in a cordless drill.
Should the bit simply pull out of the holder now that I wish to remove it - or is there something else I should be doing? The bit won't seem to pull out. I did notice when it went in that the magnet pulled it into holder with some force.
They normally pull out. Try holding the bit with pliers and pulling apart
Possibly a bit of grit is making it stick?
Problem solved. The black sleeve slides forward, however the bit was still stuck. So with the sleeve slid forward I pulled the bit out with a pair of vice grips.
