How to Replace a Radiator
20 Aug 2010
Aberdeen
Anyone with a bit of mechanical knowledge can replace a radiator on a car. Radiators need to be replaced periodically, usually because the hose necks tend to become brittle with age and break. Radiators can also be damaged by any kind of debris striking the front of the vehicle. While the exact radiator replacement process varies from vehicle to vehicle, the basic principles are the same on nearly all cars and light trucks.
1.Open the radiator drain plug, located somewhere near the lowest point of the radiator, and let the coolant flow into a catch basin to drain it. Loosen the lower radiator hose to drain the coolant if your radiator does not have a drain plug.
2.Detach the hoses from the radiator. Loosen the nose clamps and pull the hoses off of their attachment necks. Remove the auxiliary belts by sliding them off of their pulleys to gain more work room.
3.Remove the engine cooling fan and the radiator shroud. This step is vehicle-specific, and no single process will cover all types of engines. In most cases, you have to use a wide box wrench to release the mounting bolt that holds the fan to the engine. Set your cooling fan down upright to protect its clutch. Loosen the mounting hardware that holds the shroud. You might have to pull the fan and the shroud out together if clearance does not permit you to pull them out separately.
4.Remove any mounting screws, bolts, clips or other remaining attachment points. Put these pieces of hardware into a container so that you do not lose them.
5.Lift the radiator clear of the engine. This can result in a mess of coolant as the radiator shifts around, so have newspaper and a catch basin underneath the radiator.
Radiator Replacement
1.Slide the replacement radiator into place. Handle it gently so you do not damage the delicate cooling fins or hose necks.
2
Replace the mounting hardware. Torque them so you do not break the new radiator.
3
Reinstall the cooling fan and the shroud by simply reversing the fan and shroud removal process.
4
Reattach the cooling hoses to their mounting necks. Snug the hose clamps down, being careful not to over tighten. Consider replacing your cooling hoses at this time, as they become brittle and prone to failure with age. Replace them all if you replace one.
5
Install and tension the auxiliary belts if you removed them to get more room to work. Slide them back over their pulleys and adjust tension by turning the tension adjustment nuts and ....Read more
A generic fault replacement guide, in the wrong forum, will be lost in time..try posting in a car forum?
