Hi
I'm doing an upstairs bathroom and have just fitted one of the lovely 'Bathstore' triple shower valves (hot in, cold in, bath filler out, shower out).
The threads mounted inside the valve seemed unusual so I called bathstore and asked how to connect to them. They advised using parallel thread, 3/4" fittings, which I duly bought (on ebay since neither Travis Perkins, Wickes, nor B&Q appeared to stock these). I fitted these with a smear of silicone grease around the threads, noting the absence of an olive, I felt something should go on threads.
Anyway, all four are weeping when under pressure from the shower pump. Tightening them seems to make no difference.
What can I do?
If it makes any difference, in all four cases I've used copper pipe going into each fitting, not & olive on one side, straight into the valve body on the other.
Cheers in advance!
Tom
What can I do?
Cheers in advance!
Tom
