How to sink these pipes under floor ?
11 Oct 2016
Hi, I've got the old ends of pipes sticking up slightly from the floor from the old sink.
It would be better if I can cut them and sink them down a bit but access is limited.
Is there an easy way of doing this or shall I just find a trim to cover them?
I may have to re use them if I get a normal style sink in the future.
If they're embedded in concrete then maybe not worth the grief. The concrete would need cut out and the pipes cut and capped below ground level, can be done but it's a bit of farf if you can live with them.
