- Joined
- 26 Feb 2024
- Messages
- 4
- Reaction score
- 0
- Country
I'm renovating a flat and I've got curtain tracks in the main living room with only a couple of gliders on them. I want to get new gliders on the track but the glider end pieces don't seem easy to remove. They don't seem to rotate off and, if they have a screw holding them in place, it must be on the side that's facing the wall. So it seems like I need to take the track down to fit the gliders.
The tracks in other rooms have brackets with a rotating lever which was no problem but I'm not sure how to get these ones down to put more gliders on. The brackets have a little screw underneath them (pictured). I'm assuming that I just need to unscrew these but then what? Do they pull off? Or slide out? Or is there more to it? I tried unscrewing a couple of them but the track was still rock solid against the bracket. It might just be the length of time they've been up there.
