Had Nest 3rd gen in for over a year now and my hot water function has stopped working (heating works fine). When I try to boost the hot water via the thermostat I can hear a click in the Nest heat link but the boiler doesn't actually fire up. Does this click mean it is doing everything required to request hot water or does it just confirm its received the incoming message from the thermostat?
Basically I want to know if the issue is with the boiler or Nest and I cant see anyway to just turn the hot water function on from the boiler directly (Logic Heat 12 Gas Boiler). Do i just need to move my wire that is currently in the Nest 6 port to the L port?
Thanks in advance
Thanks in advance
