How to weigh 0.12 grams?
5 Jan 2003
Essex
Right you clever people :)
I want to take 120mg of powder
I understand it's 120mg x 1g/1000ml = 0.12 grams
If that's correct, how do I weigh 0.12 grams?
Are you saying 1g of powder is 1000ml........... :?
If so it's 24 teaspoons at 5 ml each.
If more likely its 1kg per 1000ml, then it would be approximately a tenth of a quarter of a teaspoon..... :roll:
Aternatively but a weighing m/c which can weigh in 0.1 gramme increments.
make four lines and holding one nostril...er i mean mix it in one litre of water and weigh it let the water evaporate and you have the result.
Don't know if the calculation is correct,
I'm confused because the way I understand it, g is gram therefore weight & ml is milliliters therefore volume
Okay slightly difference, how do you weigh 120mg or measure 120mg?
Edit: didn't see above posts
If this is a one off, why not go to your local chemist & ask if they will weight it for you.
or
Buy one, use it & return it. :lol:
'cos I don't know it all unless you got google search engine in your head :)
it doesnt work, i put a load of flour on my laptops touchpad and then googled but it didnt come up with the weight :(
