In this thread you helped me to wire a Horstmann C7 to my Worcester 24CDi. That setup has been working well since then but now I must switch to a wireless thermostat because the programmer is now in the way of a book case.
I have purchased a Horstman C-Stat 11-ZW.
As with the C7, I am baffled with the wiring instructions and the existing wiring on the 24CDi.
This is the wiring on the existing Horstmann C7:
This is the wiring situation at the boiler end:
The junction box wiring is messy because the box as originally fitted had to be changed.
There is a isolating switch not shown in the photograph. T&E runs from the isolating switch to the white connector box to the left of the first photo and out of the box runs a white flex. This disappears into the wall. Connected to the junction box is T&E as shown and a white flex.
I did measure voltages at the programmer and boiler ends but the results didn't help my understanding.
This is the wiring back plate of the C-Stat 11-ZW:
The installation manual is here (PDF) and these are the wiring diagrams:
I know that this should be simple and I have an idea of what I should do but not enough confidence to proceed and I would rather ask for help than blast ahead and damage equipment or myself.
Thank you for your help.
