hydraulic door closers
15 Nov 2005
South
Cook Islands
I have fire doors with Perko closers. The doors are being replaced with panelled fire doors for appearance, I have seen hydraulic tubular closers and wonder if they would be less inclined to slam? I am having fire frames with the furry smoke pile which stops draughts and reduces noise, and even though the door is trimmed to barely touch, it seems to slow it just as the latch should be closing, so it needs quite a firm final pull; yet I don't want them to slam hard :?
You would be better fitting a conventional door closer , they have latching speed adjustment as well as closing speed adjustment.
do you mean one that sits above the door with a box and an articulated arm? I wouldn't want them in my house. The morticed Perko style is almost invisible so looks fine.
I see, I prefer something that works to something that looks pretty.Each to their own. :wink:
this is an ordinary domestic house. Would you want Kathy Burke sprawled over your hearthrug?
so this was my original question about these neat little things
sadly no answer to that, and I am unlikely to buy
or
which are very unsightly and/or much more expensive
Hydraulic Perkos (Or similar) are very temperamental. Oil viscosity is constantly changing. When hot they slam, when cold they do not close correctly. They have some latching adjustment but not a lot. Also some panelled doors cannot accept the body depth. Good fun to fit too. Don`t forget the extended "bit".
Any "little" fingers about, these love to eat them.
How about concealed overhead closers, far superior.
http://www.ironmongerydirect.co.uk/.../49001/Rutland_ITS11204_Concealed_Door_Closer
Best closers are American ones called LCN`s, expensive but once fitted you can forget them.
Oy! I'll have nothing said against Kathy Burke.
The Geze Boxer is less expensive and does the same job - fully concealed etc, but check there's enough timber thickness at the top of the door:-
http://www
more than a thousand pounds to do my house?
I'll stick with the perkos.
Happy slamming doors then.
Thought of rising butt hinges and soft close latches?
