hygena hob
14 May 2012
Hampshire
the problem is the pan supports are only 3-4mm wide and pans particually frying pans slide like torvill and dean as the is a wide base and very little friction to stop the pans from sliding has anyone a similar problem and have they found an answer complaining only gets you new pan support which are the same as before
