I am about to replace an old extractor fan in my utility room, old fan supply came from 3 amp fused box, with Live. Neutral, Earth all 3 cables went to the fan, which operated by a pull cord on the fan.
The new fan has a timer fitted and is earthed, it has 3 connection points, Live, Switched Live and Neutral.
I was thinking of putting a 3 pole isolator pull cord switch, between the 3 amp fused box and the fan.
But I need to know where can I get the extra Live cable from, could I put 2 cables into the Live connection in the 3 amp fused box, and then make them Live and Switched Live in the 3 pole isolator switch.
Thank you
Hardley
Thank you
Hardley
