I would like to shape metal
9 Apr 2010
Cheshire
I would like to shape some metal in the fashion shown at the bottom of this lamp. I probably don't have the necessary tools and I certainly don't known enough to even know what information to search for online. Presumably, I would want to start with a sheet of aluminium? How could I circularise it? Thanks for any insight at all!
Buy some ready made aluminium tube the length you need. Job's a good un. :lol: :lol: :lol:
Any sheet metal will roll into a tube profile, using the appropriate rollers which to all intents and purposes is a mangle for metal.
The problem is, the resulting edges won't be parallel. Once thats sorted, you will be left with a join which can only really be seamed using a MIG welder with aluminium wire.
Do find some suitable tube if you can (nice one JJ) - it will save loads of grief in the end.
John :)
Thanks for the advice guys. I'm not sure I'll be able to find a tube of the exact internal diameter which I require. If I can't, I can maybe use the sheet roller at a local community workshop.
Which edges won't be parallel? The ones which come together or the curved ones?
A different choice of raw material may make your project easier to complete. Aluminium is difficult to solder or weld without specialist materials or equipment, but seams in brass, copper or mild steel can easily be closed by soft or hard soldering.
Folded seams may be possible in aluminium, or make a butt joint reinforced with a rivetted strap.
A relatively short length of tube, eg the length is less than it's diameter, can be roughly formed by hand methods , using little more than a good stout forrmer (an offcut of scaffold tube or 2" iron water pipe) and a mallet, then true it up to make it as round as you like after finishing the seam.
Fixing the base could be more problematic part, unless you could use a wooden disc simply pinned (nailed?) in place.
Model engineers' suppliers are often able to supply short pieces of tube in a variety of sizes.
Have a paw through the selection of 'big bore exhaust pipe trims' sold by Halfords and the like to see if one of those can match the size you need, or try anywhere else that sells 'round metal things' - I used a small camping billy can bought from the pound shop as a magneto cover for an engine I was building - it was exactly the diameter I needed, and cheap!
Hub Le Bas do a massive range of tubing, there's a good chance that they'll have what you need but they normally have large minimum orders
http://www.hublebas.co.uk
They have a branch in Newton Heath, Manchester. If they wont do small quantities, maybe they could suggest a local distributor.
Dandy - expect to pay up to £40 for a couple of metres of say 150mm dia. Try google for aluminium tube in the area you live or the next big town and you'll be able to get a short cut length over the trade counter, say 250 long for a tenner.
