ICE told to get the eff out
  • Thread starter Thread starter JP_
  • Start date Start date
Research shows that they can stop. Average for a police officer is 0.35 seconds to stop once threat has ended. This guy was very highly trained so would have been quicker. I would say that, before the first shot had even been fired, he realised he was no longer in any danger, because by then he could see the car was moving away. It was too late to stop the first shot. But he only continued shooting to make sure of the kill.
Never heard such nonsense, you have obviously never shot at anyone
You are talking about firing on a range or simulation, totally different to firing at someone.
An officer can generally stop shooting within approximately 0.3 to 0.6 seconds after perceiving that a threat has been mitigated, although "extra" shots are often fired due to biological, mechanical, and psychological factors. While the decision to stop may be instantaneous, the physical action of releasing the trigger involves a time-lag, often resulting in 1–4 extra rounds being fired.
  • Shooting to Stop: Officers are trained to fire until the threat is neutralized, not necessarily to a specific number of shots.
  • Continuous Fire: During a rapid, high-stress shooting, breaking the shooting rhythm to assess the situation can take longer than the threat itself, making it difficult to stop mid-sequence.
Your comment is based on a range and in a controlled environment. It doesn't reflect anything like what happened in Minnesota, no stop fire command and no start fire command. Just pure and simple shoot to kill, exactly what the agent did. Read the report you are quoting and you will see. it has no bearing on an operational job.
We need to properly break down the sequence in this case. The agent leans forward and puts his hand on the bonnet of the car to steady himself, and then he fires the first shot. The car was moving, so he gets shoved backwards. He slips, regains his footing, twists his body and reacquires the target. That is why there is a longer than normal delay between the first and second shots. The second and third shots have less of a gap between them and are what is known in law enforcement as a 'controlled pair'. Law enforcement do not use 'continuous fire'. The decision to reacquire the target and fire the controlled pair was a new and separate decision from firing the first shot. That is why they are unlawful. Because the agent made the conscious decision to reacquire the target and fire the controlled pair only after he knew the danger had passed.
AI Overview
In law enforcement and firearms training, a "controlled pair" is a shooting technique involving two rapid, but individually aimed, shots at a target, emphasizing distinct sight pictures and trigger pulls for better accuracy than a single, uncontrolled burst (like a "double tap"). It's a fundamental drill to build consistency by focusing on proper sight alignment and trigger control for each shot, helping officers ensure hits in the vital zone under pressure.
According to all the training and research, the agent had plenty of time to re-evaluate the threat and make an informed decision before firing the controlled pair. I know it seems very quick, but the human brain is amazing.
Key Takeaways on Timing:
Gap Between Pairs (Transition):
When engaging multiple targets or re-engaging the same target, a gap of 0.35 to 0.50 seconds is typical for, allowing for necessary re-evaluation of the threat.
Well at least we know you don't agree with the right to protest :rolleyes:
I've read them...
And you are twisting the words of a woman in grief who has just lost her partner!
If you say her death was 'self inflicted', then you are suggesting she shouldn't have been there whether she was persuaded by her partner or not...
So as such you would deny the right of protest...
Of course if you do believe in the right to protest you would have no problem in saying she had a right to be there in the first place!
And have you ever gone somewhere you didn't fully want to go because someone close to you persuaded you?
Or the opposite?
