ICELINE FRIDGE.. R-436
28 Nov 2006
Antrim
i HAVE A ICELINE FRIDGE R-346, NOT COOLING, THE COMPRESSOR IS QUITE HOT, I HAVE SHORTED OUT THE STAT(FUNNY CONTROL ONE AT TOP), STILL WAITING TO SEE IF IT GETS COLD, WOULD THE COMPRESOR BE FAULTY, IT SAYS ON THE SIDE THERE IS A OVELOAD PROTECTION RELAY ,,CANT FIND IT, ANYONE KNOW WHHERE I WOULD FIND IT
THANKS
JOHN
i would assume the "overload relay" would electricly stop the compressor
so the fact its running rules that out!!!!!
is the element at the back getting hot try at different heights!!!
johnxl1s said:
hi
yes the element/compressor is runing hot
jon
no expert but suspect its low on coolant although having said that i would expect the top half of the element to be cooler as its empty!!!!!
when you say element, do you mean compressor
not sure
it's a work fridge, and i would ike if possable it get going
when you look at the back do you have a wire mesh covering a large area connected to the compressor giving out heat!!!!
egnore the compressor it will be hot so should all the mesh from top to bottom
try turning it off for a day then turn it on again it may help but i doubt it
also if the top of the element[mesh]dos'nt warm up within 20 mins its probably short of gas
having said all that if its a comercial machine different rules may apply
have it on this morning , will leave it on for an hour to see, no element at back , just compressro
john
