I have just moved house, and have a Icon 23t Combi boiler installed. The problem is that the two red central heating valves are closed, as the weather now is getting a bit cooler I want to put the central heating on. Once I try and open the central heating valves all you can hear is water trying to enter the pipes and a loud banging noise, meanwhile the pressure dial on the boiler fluctuates wildly between 2 and 4 bar for 20-30secs and then settles at 3 bar. The boiler seems to let out / drip waters out though a pipe to outside (I take it this is a pressure release system?). The hot water is fine, but I can’t find any indication that the boiler has been serviced since 2001.
Do you have any ideas? I hope that all is needed is a service??
