One of my rads had started to pull out the wall fixings, so before it could come fully off I turned off boiler, isolated the radiator, drained it, removed it and repaired the wall fittings, then put the radiator back on, all was fine up to here. Then open the feeds through the radiator and turned the bolier back on which is where hit a few problems.
I'd forgotten to bleed the rad first so Boiler made a few noises I'm guessing due to air in the system and p[ressure dropped to 0, so then bled the radiator, but some how pilot light went out on the boiler, not sure if this is connected or not!!
Basically don't know where the ignition switch is on this boiler, and if just relighting it will solve the problem, any help would be appreciated!!!
