icon23t spares
18 Dec 2005
where would i be able to obtain a sealkit for a icon23t. its the joint just above the pump which is leaking.
What kind of seal is it?
Many of these are standard heating parts.
havn't stripped it down yet as it is only a slight weep which stops when using the heating. i didn't really want to strip it till i had the correct part in hand. there is a large nut just above pump that joins the pump to the heater matrix pipe. nut is approx 30mm across flats.
try standard pump washers with a bit of lsx from memory the original are rubber and if over-tightened crunch up the spares should be available through glow-worm if you go down that route unfortunately the manual does not show spares or part numbers.
