Pleeeeaaasseee can somebody help!
I've had a (less than) ideal isar combi boiler for a number of years now and I'm having problems with it firing up.
By looking through the other forum posts I'm feeling lucky that mine has lasted for so long (about 5yrs now) without any major problems until now.
The problem that I've got is that sometimes the boiler works fine (phew!) but other times when it feels like it it just refuses to work.
What happens is that it seems to shut itself down and either flashes "E"&"H" or "E"&"S" and refuses to do anything.
If I switch it off and on it usually, eventually, decides to work again, but more and more frequently it just sounds as if it's about to fire up (you can hear the initial 'click' but nothing else comes to life) but then does nothing.
I've had the cover off when trying to switch it on and off and it feels as if something either on the PCB or the Actuator is trying to switch but isn't managing it.
Oh and finally, when I press the 'reset' button is does absolutely NOTHING - I'm beginning to suspect this button is just a cunning decoy and is in fact not connected to anything.
Any help would be very gratefully received (especially as it's -2 outside at the moment)
