Ideal 24 cracked sump
10 Oct 2019
Seems to be a common problem. Question I have is does the boiler have to be capped and made safe once a small drip has been found? Or can it be run until a replacement part is fitted in a couple of days?
It's classed as At Risk, so it doesn't need to be capped but should be turned off and a warning label attached advising the user to leave it turned off until repaired
