Greetings!
I have a Worcester Bosch 40 Cdi Conventional boiler.
Recently it started leaking. The plumbing engineer that visited diagnosed a damaged sump, with the water escaping from a hole/crack in the sump as opposed to moving along its normal channel.
The engineer went off to investigate if a sump could be purchased in isolation from the heat exchanger and came back with the fact that a whole new heat exchanger unit would need to be bought £450 and it would take two hours labour £250.
My question is, is it possible to purchase just a new replacement sump anywhere online? Buying the whole new heat exchanger unit seems somewhat overkill.
Any help in saving me a good few £££ would be greatly appreciated.
