Ideal Boiler not Working..Please Help :(
15 Aug 2011
Hi
My Ideal isar HE24 has stopped working :(
My handyman managed to stick a nail through a central heating pipe (under the floor boards) last night and as a result the boiler leaked out all the water and eventually started making strange noise overnight. I didn't manage to turn off the boiler last night and today he managed to locate the leak and i had it fixed by a plumber. Unfortunately when trying to switch the boiler back on, i get the display flashing between "0" and 3 horizontal lines (cant work out if that is an "E" or a "3" because there is no vertical line on either side of the 3 lines).
The plumber tried to work out the fault but was unsuccessful. When switching on, you hear a switch click but then nothing else comes on apart from the display flashing between "0" and 3 lines. He tried the reset button, switched the boiler on/ off from mains switch, trying to start when running hot water etc and nothing.
Can someone please please help as its freezing cold and i cant do without heat and hot water or too long :(
thanks so much in advance to the great helpers in this forum!
Aaliya
thx for the reply gaz, yes was refiled, the gas supply is fine too.
i just went and tried. this is what happened...
it was off from the main supply
when i switched it on the heater light actually came on (which it didnt about an hour ago and i heard water going into the boiler (without me doing anything)
then it stopped and display went to "d"
i tried switching thermostat on/ off a few times...nothing happened
reset button does not do anything at all, no response, stays on "d"
so it is behaving differently to how i originally described it in first post (which was the actual case an hour ago)
thanks again
Which model of Ideal boiler?
Whats the pressure on the boiler now?
Why do you employ a plumber who cannot deal with simple plumbing problems?
Are you in Coventry?
Tony
have another read tony
d means its trying to fire for hw (preheat). it might be airlocked, turn the stats down on the boiler n keep the ch on (on the timer/stat).
Hi
Aaliya
I have read it again and I come up against the same problem. She employs a plumber who cannot deal with a simple problem even though he is there in front of the boiler!
Why employ someone who cannot sort simple problems?
Hi
i was referring to what boiler shes got, the other bit i agree with. to add to the criticism to the people shes employed, i would also say the handyman doesn't sound very handy :lol:
hi gaz
can u pls elaborate? it seems it was "trying to start" but didn't quite get there. u mean turn down target temp on thermostat?
thx again
hi Again to anyone else who may be able to help please....?
->> i had the boiler off from the mains overnight
->> i switched it on this morning, it tried to start again with the burner coming on, i heard some water slushing around inside, a couple of clicks but after about 1 minute it went off. i had the thermostat off in all this time
->> i then switched on the thermostat, it made the noise to suggest it was gonna come on but then displayed the "L9" error.
->> i hit the reset button and then it went into (and stayed in) flashing between "0" and three horizontal lines mode.
thanks in advance as always everyone!
Aaliya
hi
what is the best way to pinpoint which exact part is the actual problem without changing each one? btw, by "heat" i assume u mean heat exchanger?
thx again
ethier pump gone or the heat has or you got problem with the over heat stat
Tony, your not really helping here are you?
Can't you go and find a restaurant that needs reviewing? :wink:
now when i switch on and off, it just flashes "0" and 3 horizontal lines, nothing else is happening now
