ideal boilers isar m30100
13 Nov 2008
London
hi
can anyone help me with my boiler problem.
i have had the system flushed and serviced and the pump replaced. i use a electric shower, therefore dont use the hot water much.
i have a fault reading of LF cant get rid of it, ive been told it may be a ignition problem that all the burners are not firing up, it does make a loud vibrating noise a a second or two, i have re-set which only does the same thing again.
has anyone have experience with this? or can advise.
please help.
thx
you need to get someone to look at it really.
loud vibrating noises with LF faults are usually a blocked sump or condensate trap.
I agree with nickso, the problems u have lead to explosive ignition and whole heap of problems. I can assume that the boiler hasn't been serviced recently or indeed correctly :?
Get a local suitably qualified engineer to do it, before u have to spend alot of money my friend :lol:
could be air gasmixture check flue seal. Also could be holed hex at the back of combustion chamber if boiler has not been serviced the insulation panel may have dropped in front of burner. Also gas valve could have water in it from condensate in bottom of combustion chamber.
